Beau Lawrence
I know I am getting old when I can't remember which bulletin board I left which question. I would really like to hear from a 23.5 or 240 owner who has rigged for a cruising spin. Did you use a 3rd halyard? I will be using the jib halyard b/c my furler has its own internal halyard. Does this impact sail shape? I was thinking about attaching two blocks to each side of the boat to handle the sheets. The sheet would run from the sail to a block at the stern, then turn and run to a block mounted on the base of the stanchion in front of the winches (even with the mast) and then I could terminate it either on a winch or cleat. Feel free to email me directly if necessary.Thanks
