23.5 Mast light- deck connector info needed
Mike B.
I pinched the electrical connector that connects from the mast lights to the deck connection on my 1993 Hunter 23.5
It happened when I was raising the mast and the connector jammed between the bottom of the mast and the mast deck plate and got squished.
It is the OEM round, female threaded, screw-on connector for the mast end, with three pin connectors in a triangular pattern. I would like to know where to find a replacement ,or who manufactures it, if anyone can help.
I have tried W-Marine, Perko, Ancor, all to no avail.
Thanks in advance.
Rick Webb
Replace the Whole Thing
Everyone has problems with these corroding up. I replaced mine with an Aqua Signal unit from West Marine and it has not been a problem since.
