2016 Beneteau 381: does the table drop to become a bed?
Oct 8, 2013
33
Beneteau 321 1999 Rose Haven, MD
A very specific question in this post’s title. We have just bought this boat, and see that the table top can be removed from the two metal pedestals, but it does not clearly convert to a bed (as in our older ‘99 321). And, the table top does not slide on the metal pole as in prior boats. Was there an option for this boat for the table to convert to a bunk? Are we missing pieces? or is that just not a thing?
Mar 20, 2016
595
Beneteau 351 WYC Whitby
On the 351 you remove the legs and there is shorter ones to support table ,mine are missing however the table still supports on 3 sides of bench and we have used it without legs. A couple years later Beneteau got rid of the legs and went to bracket off compression pole. I picked a bracket up and it is available from beneteau to get rid of the legs altogether.... just bring your wallet
Feb 19, 2020
16
Beneteau Oceanis 38 Newport R I
I have a B38. There are 2 set of table legs. There is a shorter pair of the same tube type. they are about 12-15 inches. If you would like i will be going to the boat and can measure and send a photo along if that helps.
