2008 Hunter 33 Anode Replacement
Jul 6, 2019
7
Hunter 33 Newport, RI
I am trying to find the correct size of anode for my 2008 Hunter 33 sailboat. Does anyone know the correct size I need? Thank you.
Apr 8, 2010
2,251
My SWAG is that given size of your boat it is 1". As suggested, just measure it from inside the boat to really know,
Jun 25, 2004
662
Hunter 306 Pasadena MD
Sorry: do you mean what size of zinc to clamp to your prop shaft? (Or do you mean a protective anode for the engine, or do you have a sail drive, or something else?) Our 2004 H306 has a 1" shaft (agreeing with FastOlson's guess above), but again, it's just a guess as to your prop shaft size.
Jul 6, 2019
7
Yes, I do mean the zinc anode to clamp to my prop shaft. I tried a 1 inch and it was a tad too small.
Jun 25, 2004
662
That was my guess. Marlow-Hunter is doing all sail drives now, but in 2008 I think they were all conventional direct drive. So assuming you've done this before (so you know there's a bit of a crank-down factor to get the zinc to seat on the shaft), I'd guess it's 1 1/4". I'll also assume you're asking because your boat isn't very close by, otherwise you'd probably look in your manual.
