2008 Hunter 25
92
2 216 lake murry, South Carolina
I have always wanted to put a head in the boat. Can I use the same seacock that discharges from the sink for the intake to the Head? Does anyone have some pictures of the set up so I can go by. I appreciate any help. ds
Sep 1, 2009
61
2006 Hunter 25 Lake Travis, Texas
no pics, but I can tell you
The way it is set up on my 2006 H25 from the factory is that the seacock for the head intake is right next to the seacock for the sink drain. They both sit below the same access panel just a few inches from each other. I see no reason why you can't use the one from the sink.
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
The suction from the head pump may draw the water from the sink discharge fist because it would be easier. Then you would suck air. A simple fix might be to seal the drain with the sink plug when using the head pump. It would depend on how much water column you have in the sink drain.
Feb 5, 2009
92
thanks all, that sounds great! does anyone have any pictures of the set up at the holding tank? d
-na -NA Anywhere USA
second that on a seperate seacock. When drilling thru the floor, always go slow and not punch thru as some folks do.
Feb 5, 2009
92
thanks for all of the help. I am going to put a drain out the side like the H260 and use the seacock for the head.
