2008 hunter 25 job jib
92
2 216 lake murry, South Carolina
Had great sailing today in Columbia SC with 17 mph winds. The top of my jib torn and jib came down. I will get it repair next week, but how do I get the halyard down? thanks for any help. ds
-na -NA Anywhere USA
I am not sure if you are talking about the 216 or 25. If the 25, you could bring the main halyard around and use it in place of the jib halyard to lower the mast. I would not use it for lifting the mast up. You do have to be careful and take the end of trhe main halyard line and tie it off to a cleat even though it probably goes thru a rope clutch.
If a 216, then you manually have to drop that mast.
