2008 B43 bilge pump fuse location
Jun 6, 2004
30
Beneteau 43 Milford, CT
I have a 2008 B43 and I am trying to find the location of the 15amp fuse for the rule bilge pump. It is not getting power. I believe from the schematics that it is on wire 14 which should coincide with breaker or fuse 14 as well. Any help would be appreciated
On our Oceanis 37, although there is a switch and fuse on the main panel for the bilge pump, the pump is also separately wired directly from the battery through a fuse in the battery charger compartment. Not sure if the 43 is wired the same way, but it may be worth tracing the wires that come from the house battery that don't go to the main panel.
May 24, 2004
7,209
CC 30 South Florida
If the pump is directly wired to the batteries there should be a fuse on the positive (+) wire close to the battery terminal.
Gunni
Mar 16, 2010
5,937
What David said...does the pump turn on when you throw the manual-on switch at your breaker panel? Your pump has two power sources, if neither work the pump is toast. Don't think the OEM was a Rule.
