Rudder Mod
Hi Garry,I was wondering what hardware you removed to allow the rudder to swing out of the water? Did you add any other brackets?I questioned the Hunter dealer last summer and he said that there was a bulletin from Hunter that recommended that the rudder not be modified. The concern was two fold. One the rudder would loose it's ability to "kick up" and you would risk a broken rudder. Two, with the hardware removed, you would not be able to "lock" down the rudder properly while sailing. Can you comment on the above? I would like to try the rudder mod first.My Hunter 25's rudder gets really dirty and slimey in the slip. I was thinking of putting an ablative bottom paint on the rudder.
