2004 Beneteau 331 - Fresh Water Issue?
Nov 25, 2025
5
Beneteau 331 Bohemia Harbour
I just purchased my first sailboat and I’m very excited. I started winterizing by pouring a few gallons of antifreeze into the freshwater tank. With the freshwater pump on, I saw a little water flowing from the sink (not pink yet), and then it stopped. Now I’m not getting any water from the bathroom or the galley sink.
The water pump runs, but no water comes out at all. I plan to study the layout and watch some YouTube videos, but is there anything specific I should check first?
Thanks in advance!
Congratulations and welcome!
My guess is that the pickup tube is above the bottom of the tank, so the pump consumed what it could and then ran out of antifreeze. It’s also possible the pump got a bit of an airlock and stopped pulling. In theory the pump should be pretty good about self-priming, but I’ve had problems with that before. I’d start by trying to disconnect the output from the pump itself to see if you get pink that far. If not add another gallon to the tank. If you do get pink from the pump outlet then reconnect it and run the pump again to see if it gets to the first sink.
If you have two tanks make sure the manifold is set to only pull from one, and that it’s the one you’ve added the AF to.
Likes: Gator70
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
Next time, remove the hose from the tank, and stick it in a gallon jug of AF. I have a little pigtail that I can screw on to the tank hose fitting to extend it an extra 18”. Makes winterizing the water system pretty easy.
It sounds like the AF has already been sucked up into the system and now the pump is pumping air.
the AF has to displace the water in the lines, pump and accumulator if you have one.
Add more AF.
Greg
Jan 7, 2014
462
Beneteau 45F5 51551 Port Jefferson
I have 5 tanks and the pickup in each is an inch or so above the bottom. I put a Tee in the hose right after the manifold and before the pump with a 1/4 turn valve and put a hose into a gallon jug of AF. I can do the whole system with 1 or 2 gallons. I use a shop vac at the strainer and open each tank valve one at a time to clear any water between the tanks and the mainfold.
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Use a compressor and blow your lines out. Much easier when it comes time to recommission in the spring. And now you have a bunch of antifreeze that will be in the tank so you’ll have to add water and drain many times to get as much possible out….. unless you have an access port in the tank and can use a vacuum
Good luck!
Greg
s/v Souleil
Likes: Gator70
Bum
Mar 18, 2008
35
Beneteau 331 w/swing keel New Gretna, NJ, Bass River
I dump about six gallons of the pink stuff in the fresh water tank which is probably overkill. but that is plenty to be over the intake to the pump. After I run the pink stuff through all of the freshwater lines liberally, I then reclaim the unused anti freeze from the tank back into the bottles at the sink faucet. I stop reclaiming the pink stuff when the pump starts losing suction, Immediately. We bought our Beneteau 331 which we keep in NJ, new in 2004, so far so good. Pink stuff is cheap compared to the possible issues.
