Beneteau problems
Steven; I bought a '94 OC400 in 1997 through a very prominent So. Cal. broker, Southwest Yachts of San Diego. A reputable surveyor went over it. The sea trial was a one-hour motor in flat calm. As soon as I took possession, problems started to crop up, most of which were connected to shoddy electrical work by the commissioning dealer, Southwest Yachts. The inverter and radar/plotter worked, but not exactly the way they should. There were many shortcuts taken. BeneteauUSA was almost no help and neither was the broker. There were many problems that shouldn't have been there with a boat so new and the builders installation of the Italian-made freezer/refrigeration left a lot to be desired, electrical-wise. There was no attempt to control corrosion, resulting in repeated failurs. I spent a small fortune on electricians searching out problems with the alternator, inverter, radar, plotter, not to mention the freshwater system and the macerator system. The Perkins diesel seems OK, but many of its bolt-on parts, such as starters and solenoids and water-injection fittings on the Vetus muffler failed early and had to be ordered from England. I had to have the water-injection fitting custom made in order to go on a planned cruise. It took nearly six years to get everything working and there are still electrical and reefer problems. The boat sails very well but the roller-furling main is very tempermental and has to rolled up just right to work smoothly. Try to avoid the under-deck furler for the headsail. It looks great, but it doesn't work all that well, too many turns in the furling line means too much friction. If I had it to do over, I'd buy a locally-built boat with all American gear and hardware like a Catalina. This is all JMHO.
