2001 420 Passage Maintenance on Steering System
Aug 29, 2018
57
Hunter 420 Passage Sv
We have a 2001 420 Passage that is new to us. I want to do maintenance on the steering system and would like advice. I see 2 grease fittings back near the rudder post, are there any others?
What type of grease is recommended for the cable? Is there a grease fitting for the rudder shaft, if not how is the shaft to post lubricated?
Stephen, do you know the manufacturer of your steering system? They usually have manuals you can download to answer all your questions. Good luck.
Jan 12, 2011
930
Hunter 410 full time cruiser
I have the sister ship 410 and bet they use the same steering system, if so
there are the 2 grease fittings you mentioned and no other I know of
the rack ball joints should be cleaned and lubed once in awhile
there's a note about spraying the pedestal with protectant, I've had the protectant and boat for 9 years and still haven't done it and the pedestal looks just the same with no corrosion
Aug 29, 2018
57
Thanks for the advice, Gents, appreciate it. It is a Whitlock set up so i will see what I find online.
