On my 2000 340 my Depth Transducer and Speed Indicator haven't been removed for a few years, at least.
The Depth Transducer works fine and accurately, to within at least 1 foot below the keel.
The Speed Transducer is not in. Just the plug, as it is a constant fouling issue with the spinning wheel.
Has anyone used Transducer paint on the Speed Indicator Wheels without any issues in readings? Or just not using it at all?
Since I want to remove both before launching to clean some paint residue around the edges, do you use any grease on the O Rings, like Super Lube, Mar Lube etc?
