Never had this issue before, last year when hoisting the jib into the track the sail start to get difficult to pull up after it reached approximately 3/4 up the track. Lowered it down about 1/2 way and had to winch it up the last 10% of the way up. When lowering it at the end of the season it normally just drops after releasing the rope clutch, but had to give it a few tugs downward and after a few feet it dropped to the deck with no trouble.
This spring had the same issue, this time about 1/2 way up the track. Lowered it down again and switched to the other track and raised it again. It jammed again about the 1/2 point.
lowered the sail three or four times and it keeps getting stuck 1/2 point. Normally I can just hoist it up by hand. This year had to winch it up the rest of the way to the top.
Nothing has changed the past to season's also checked to make sure that the halyard didn’t somehow get wrapped around the track. Everything appears to be clear and working. With the sail out of the track I look up the tracks to see if anything was bent or any kind of obstruction.
I don’t see anything. The leading edge of the sail appears to be in good condition as well.
my thoughts are that some kind of dirt or grime is in the track. I’m at a loss why it keeps jamming. I’m thinking about somehow getting something to fit into the track and using some soap to run it up and down the track to see if that works. Any suggestions would be appreciated
Or if anyone else has had this issue. How you resolved it.
