Yep Terry,
And that brings up the question, Why? As Colin says, It's the conductor that counts. 30 amp service is 10 AWG and 20 amp is smaller. Again, why would anyone have a setup smaller than 10 AWG?Todd, check the wire on your boat from the shore-power inlet to the main breaker. If it's 10 AWG your in good shape, no worries.Terry, years ago when I was at the Port Orchard Marina, the service was 20 amps. The molded cables were getting popular. If you didn't make your own from scratch, then you had to used an adapter or cut off the molded 30 amp twist lock. I've still got the cut-off end to the cable of my Hunter. To this day, I have to use adapters. Even on my short bow cable. It's annoying, but only because I haven't bothered to change back. I've been a little busy.
This thread reminds me of Nuavo Vallarta. It was under construction in 92 when we were there. The outlets for shorpower were the inlets used on boats. Everyone of them (hundreds) were wrong. Each yacht had to use a set of three wires cut from nomex to jumper to their power cord. Everyone who arrived would tell the marina of the incompatibility. The response? The office workers just handed us three pieces of wire. The new floats were being wired wrong as we jumpered our cable. Ah, Mexico.
