Tom
Hello fellow trailer sailors,My 1999 H260 was very dry the first two years, but water is coming in, starting last season, and I still haven't figured out the source. So I am looking for advice from others that may have had similar experiences:1. Water in the light above salon table. I'm almost certain that water must somehow be coming in around the mast base and/or center board control hardware. Water appears only after a heavy rain. Could the fix be as simple as running a bead of caulk around the mast base hardware to deck joint? Other suggestions?2. Water gets into the cabinet floor under the sink in the head. It is coming from under the liner. It will sometimes be there after a heavy rain. Also, I have noticed that the boat is dry before a sail, then after a sail, salt water will be in this area. Salt water also finds its way onto the aft berth, under the cushions. I have removed the cushions to monitor the situation and to keep them from getting wet. I haven't completely characterized the circumstances, but here is what I have noticed, so far. The water appears to be coming from the port side, maybe running out from under the liner. The wall covering (and cushions) are wetter on that side. However it does trickle across to the other side, and also finds its way into the bilge, beneath. The area behind the aft bulk head is wet forward, but the aft portion at the very back of the compartment is dusty dry.All areas forward are dry: under salon seats, under galley cabinets, under V-berth, etc.I placed a paper towel in the water ballast fill plug area to test if water was coming in there -- nope.Although there is a little water in the bilge, the bilge pump is dusty inside, so water is not siphoning in the outlet. I tightened and check if water is coming through the bathroom sink through hull -- nope.I notice water, I think, only after pretty breezy days when the rail gets dunked during a gust. On light wind days or when motoring, the boat is dry after an outing.Could it be possible that a leak has developed in under the rub rail, at the deck hull joint? Would this allow rain water to get in, too? If so, How can I get a look at it? Does the rub rail come off with out destroying it -- and, if so, how?Any suggestions would be appreciated.Thank you,Tom
