2 GMF Starting Battery
Pete
Plan to add a battery reserved just for starting the 2GMF Yanmar on my H31. I would like to use a small battery; anyone know the minimum amperage reqyuired to start these engines? Thanks.
Dec 2, 1999
15,184
look at the AGM from Optima
Pete: Check out the Optima AGM small and powerful. Just what the doctor ordered for your application.
Bryan C.
Cranking battery
Amp hours is not the consideration for a starting battery, cranking amperage is. Since you will not be deep cycling the starting battery (which will rapidly destroy it) you don't need an expensive deep cycling battery. I bought a 600 cranking amp "marine" starting battery a couple years ago at wal-mart for about $40 and it works fine on my 3GM30F. Should be fine for the 2 cylinder 2GM. I keep it charged up and only really use it as an emergency starting battery, using my 200 AH house bank for normal (including starting) electical chores.
Jim McCue
2nd battery
Plan on adding a Guest battery isolator and 2 battery switch.
