Smoking Diesel
I owned a 1985 31 for 9 year. Mine could'nt do over 2100 rpm. The reason was that the previous owner had replace the original prop with a 3 blade. However, this did not cause black smoking unless the prop had barnacles. Your problems is likely one of the following:You prop is fowled with barnacles, or a line. One or both injectors has a bad pray pattern(see your manual). The previous owner re-proped the boat and the prop shop did a bad job sizing the prop.With a relatively clean bottom, your boat should make at least 6.5 kts in calm water under full power. If she can make that speed, then it means your prop is probably mis-sized, That's really not a problem however, just don't push the throttle to the point where she smokes. Let me know if you have more questions, you can find an e-mail link at the following.www.cccdelivery.com
