Propper Prop
I just relaced my 2 blade on my 35.5 with a 3 blade Michigan Sailer 16X10. My engine is a 3 GM 30 F and while the boat is a little larger than yours the new prop is just about on the money with a cruising speed of 3200 RPM [ideal would be 3400]. Next year I might pitch down to 16X9 to bump up the crusing RPMs a smidge. My point is a 16X10 is probably righ for you, but go to Michigan wheels web site and they can give your the correct prop specs instead of my guess. You will need to tell them the trans reducing gear info [mine was 2:61 to 1], engine info, boat displacement, cruising and maximum RPMs.Good luck,Fred Miller S/V M SquaredPS The 3 blade prop made a mega diffrence in maneuverability and speed under power without much drag loss under sail if you go to the SAILER MODEL.
