1GM to 2GM upgrade
David OHara
My old 28' S2 has the old 6.5 hp Yan 1GM engine that seemed underpowered in thunderstorms and heavy headwindsa and seas. With her out of the water for awhile, I have obtained a good 2GMF 13 hp engine and will probably replace the 1GM. I want more power in bad situations and the ability to motor for days at a time when there is little wind. So, the question is; 2 blade or 3 blade? I had a 3 blade with the old engine that I may put back on and have it re-pitched. Folding prop would be nice but too expensive. Any suggestions?
Dec 2, 1999
15,184
Read this thread.
David: Read this thread. The same go for your situation as with these other boats. http://www.sailboatowners.com/forums/pview.tpl?sku=2002338101731.71&forumabr=pdt&fno=120 If you are pleased with a three blade prop, then just have it reworked. If you want to sail a little faster and still have the power to move you, consider a two blade with winglets.
