1999 H410 Forward Shower Sump Replacement Issues
Jan 20, 2020
25
Hunter 410 Cast off from Cape Cod
I'm running into trouble as I've been replacing the original Atwood Sump in the forward shower sump. I found a Seaflow 750 GPH box would fit the limited space available and configured the hoses to make things work. I'm having trouble with he outflow overboard. The box pumps out but the pump struggles for some reason and never shuts off. I've flush the line with water and it seems to be ok?
The original Atwood box was disconnected due to a burned-out pump. I couldn't get a replacement hence the new box. But if the Atwood suffered the same issue (nonstop operation) it surely would explain why it burned up.
Any thoughts?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Also check the suction line is clear by augering it with a hand held or drill auger.
Feb 21, 2013
4,638
Suction line ...... from the shower drain to the pump. Maybe blocked with hair?
Jan 20, 2020
25
Thanks, but that's not it. The water flows fine into to the sump box. It's the ejection process when the pump cycles in where I'm having the problem.
RoyS
Jun 3, 2012
1,742
Centrifugal pumps have great difficulty overcoming any check valves in the expel line. IMHO these shower sump boxes do not work.
JamesG161
Feb 14, 2014
7,815
Hunter 430 Waveland, MS
When done with lavatory/shower use...
Turn the DC panel breaker off.
Jim...
Likes: RoyS
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I replaced mine several times. I finally made my own sump pump system. I used one of the standard sumps that would fit. Installed one of those sensor level units rather than a float. Then used a pump large enough to overcome the head to exit the boat.
The sytems works fine. Although, it only pumps for a few seconds then shuts off. It gets the job done.
Most of these sump systems are junk. For the main system I installed a whale system. I think these are the best available.
Jun 1, 2009
1,845
Hunter 49 toronto
Respectfully, just get the Whale IC system, and you’re done.
Basically, you’re trying to re-invent what they did a really good job of making into a commercial product.
Yes, a sump box is cheaper. But, it’s a constant maintenance headache over the years, and not worth the aggravation. The impeller pumps they use in sump boxes continually clog up, and it’s a disgusting job (second only to head fixing) that I just got tired of.
There are lots of folks on this forum who agree with my suggestion
Aug 18, 2018
146
Hunter 410 MDR
Don't laugh, I had the same problem, I glued a dime to the float.
This might work for you, test by pushing down on the float when it has trouble stopping.
Also my 410's forward sump will cycle on off because of the backflow of water in the line, so we only use the main aft stall.
Usually we have the breaker off unless showering.
Jun 4, 2004
1,087
How do you use this system when you have more than one input? Always thought this would be a good system but need a box to collect from multiple sources.
Jan 20, 2020
25
Thanks Sailgunner. What consists of a ‘large enough pump’ to overcome the approx. 3’ head lift? (is that the issue here?) I see that Whale make a great looking compact sump system that would fit the space available but it's not distributed in the US. I went down the path of retrofitting my original Attwood box with a new pump, float, etc. But I found I was having the same issue. Could it be something with the discharge line itself that I'm missing?
Jun 4, 2004
1,087
Yes, just need to overcome the 3' head.
Jun 1, 2009
1,845
Hunter 49 toronto
I respectfully suggest just purchasing the Whale IC system. It works flawlessly, and you’ll never have to deal with it again once installed.
Jan 20, 2020
25
Thanks everyone! I’m hearing that the Whale IC is the way to go And I do like the idea of eliminating the sump box entirely. My only remains concern is how the Whale will function with the AC condensate drain which is also fed into this sump. This is more of a trickle than a flow of water.
Jun 4, 2004
1,087
Good question. Also can you tee the head drain and condensate in the same line?
