1998 Hunter 340 Condensing Unit ?’s
May 16, 2018
8
Hunter 340
Hi all,
Replacing condensing unit: Would you recommend Adler Barbour or Dometic 85 for a 1998 Hunter 340?
Anyone know the cubic feet of the refrigerator unit?
Thanks in advance!!
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Do you have the manufacture/model/serial number of the existing condensing unit? Could not find any references on the internet for a 1998 Hunter 340 refrigerator's cubic feet but you can easily measure the refrigerator inside dimensions then calculate the volume. Considerations of whether to select a Dometic or Alder/Barbour are dimensions to fit existing location, cooling capacity required and local service availability. Please see the links below for Dometic 85 (cools up to 8.8 cf and is 6-1/8"H x 8-3/4"W x 8-3/4"D) and Alder /Barbour Coldmachine CU-100 (cools up to 15 cf and is 7.5"H x 10" W x 11.1" D) condensing unit prices:
