Hi,
I’m new to the forum and looking for some advice. I’ve a Catalina 42 Mk II and I’m having problems with my fridge. The compressor runs file, but the cold plate is not getting cold. It is getting some condensation on the plate which makes me feel that its operating but its a coolant issue. The systems takes R-134a. I’ve looked at the compressor and researched adding coolant to the system. Advice talks about adding through the suchion / low pressure port. However, I can’t find a description / diagram to identify which is the low pressure port. One value is at the end of a short pipe coming out of the main ‘flask’ of the compressor, the other seems to be between the ‘grill’ and one of the pipes leading to the cold plate. This second one is on a ‘T’ joint . At the bottom end of the ‘T’ joint is a white canister. I’ve also read about purchasing a recharge host & gauge (+ can of 134a) from an auto parts store.
Any suggestions please ?
Thanks in advance
Thanks in advance
