Used boats
Brian;You are correct that prices do vary alot but there are many factors to be considered. First are the options found on board for example the Hunter 26 in the beginning did not have stern rail seats but the later models did. The 26 did not come with an option of wheel steering from the factory. It was an aftmarket item and unless it was done correctly, installation could be sloppy.The condition of the boat and equipment is another factor. Does everything work? How much will it cost to repair and/or replaced. One boat may be higher as it is in pristeen condition versus one that is not been taken care of.Later models might have warranties still in place. Another factor for example is the Hujnter 26 was refined.Another factor is salt water corrosion and that goes back to the owner taking care of the boat. Freight to the west coast is higher than the east coast.As I have indicated, there are many factors when looking at a boat and hopefully this will help you from a dealer perspective viewpoint. If buying used from a dealer, see if he will stand behind it. The Hunter 26 and now the 260 are two good boats that I firmly believe in.Crazy dave Condom Whoops! I mispelled my last nameps I had many pet names growing up
