1994 Hunter 23.5 Battery
11
- - Cedar Hill Texas
Hello. We are new to sailboat ownership, and have purchased a 1994 Hunter 23.5. As we make her ready for the first outing, I am sure we will have many questions. My first one is the location of where the battery should go. I have not had time to trace any wires, and any information would be helpful. Thanks.....jer
Jul 6, 2004
8
Hunter 23.5 Farmington Hills MI
Re: 1994 23.5 Battery Location
Welcome to sailing. The 23.5 is a fairly simple boat so it should be a good choice. The stock battery location is under the starboard berth to the right of the stairs. There is a small platform molded in to the hull. Make sure the battery is inside a plastic case and strapped down to avoid spilling acid when the boat leans. On my boat, I moved the battery under the sick to balance the weight of a 4 stroke outboard motor. There is a platform molded in there too. It is a tight fit to get the battery into that location. The 4 stroke motor is heavier but the pollution is so much less. Have fun on the water! Gary Nichols Farmington Hills, Michigan (with relatives in Dallas - good boating there)
Apr 14, 2007
11
23.5 battery
Gary - Thanks for the fast response. I will check this out tonight. I hope to have everything ready to go in a couple of weeks!!
