Merrill
Our Hunter has a Foss Foam Rudder installed. The top of the rudder post sits underneath an open cockpit grate on this particular model. When cleaning out the collected rubbish in this well, I always notice that there is some pieces of what appears to be foam loose in the top of the rudder post. What is the likelyhood that water is getting down the rudder post and into the rudder. Can I assume that the rudder post is well sealed at the top end? If not, what would be your recommendation to "seal off" the open end? I have tried to locate a good quality white antifouling paint for the rudder.....any suggestions....I always seem to end up with a grey. What is the safest method for removing the old antifouling paint? ThanksMerrillAmbition
