1990 Hunter 30T genoa tracks ends?
Jun 9, 2004
21
Hunter 30_88-94 Port Charlotte, Florida
Anyone know where to get the little moldings that stop you catching your toe on the end of the genoa tracks? Mine have disintegrated over the year
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
4 new ends just arrived from SBO a few days ago. They had the best price that I could find with shipping. You probably take the same 1" ones as my 91 30T.
Jul 7, 2004
8,542
Has anyone had trouble unscrewing these end caps. The first one I tried is stuck. Won't budge with a phillips screwdriver. I tried turning it with my impact driver by hand. Before I hit the driver with a hammer I thought I better ask. What is behind this screw? Am I going to mess something up if I try harder?
Dan_Y
Oct 13, 2008
524
Hunter 36 Hampton
Wow - they came out okay from my '91 h30. I think they take a #1 phillips. Eddie B. told me the entire track is screwed into an aluminum plate glassed into the deck so I assume the end stops are also. Once you free it, put teff gel on the new screw.
Jul 7, 2004
8,542
Thanks Dan. Sounds like it has solid backing. I'll spray some PB Blaster on it, let it soak in, and try again.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Inside is an aluminum piece that is drilled and threaded. I used an impact screwdriver and it worked fine on ours. I had to run a tap in to clean the threads before putting the track back down. Ours was up to rebed it for a water leak. 1989 Hunter 30.
Ken
