Dave Swanson
I have a 1989 H30. It has 2 group 24 batteries port of centerline under the aft near the engine. These batteries are used for both house and starting loads. I would likt to upgrade the size of these batteries and add a dedicated starting battery. Has anyone done this on their H30 or similar vessel? Where did they locate the dedicated starting battery? How big of house batteries did you upgrade to? What type were they (gel, AGM, lead acid)? It appears that I can only get 1 group 27 and 1 group 24 to fit in this location (in battery boxes). The hull slopes upward so the port battery does not have enough clearance for a group 27 battery (because of the length). Is there any problem with using two house batteries of different sizes? Does anyone know of a manufacturer of a "small" gel, AGM or similar starting battery that I could easily locate near the engine? Any and all advice would be appreciated. Thanks.DaveS/V GetAway
