My C30 has a radial drive wheel mounted in a shallow well located aft of the Edson steering pedestal.
The steering mechanism uses chain and wire to turn the rudder. In this boat it is not possible to slacken the wire since the wire has Nico compression
fittings at the point where the wire turns around the corner and into the eye bolts. This all started with me trying to change the control cables and pull them up to one side of the steering shaft at the top of the pedestal. The chain has to be slacked off enough to lift it off the sprocket in order to pull the control cable block up and disconnect the cables.
Someone out there must have a similar situation.
Thank you,
Jim mcmullen
Thank you,
Jim mcmullen
