1986 Hunter 28.5 prop strut
Mike H.
The prop strut on my 1986 Hunter 28.5 is bent. Can anyone tell me where I can find a new one? Thanks in advance. Mike H. - H28.5
Phil - SailboatOwners.com
Try here
Hi Mike, The first place to check is Hunter Marine at customerservice@huntermarine.com. Also, on another note, I'm sure that one post will get all the input you need. No need to put the question in all forums. :)
Rick Belew
Strut can be straighten
I bent mine 90 degrees and I heated it with torch and straighten it back with no problem. Of course you will have to realign it with transmission and replace cutlass bearing.
K
kevin
I would also check Hunter
Hello Mike, I to would check with Hunter. They can provide off shelf stuff where a fabrication shop would have to custom it up. Kevin
