L
Lawrence Wittenbrook(chemwitt@aol.com)
We started our Spring Maintenance chores on "Blue Laredo", and much to our surprise discovered about 15 gal. of water in the bilge below the cabin deck. Boat is stored on a trailer. Careful inspection uncovered no stained areas, cushions removed in the fall were all dry. No water under the cockpit area. The assumption is the leak is below the waterline;possibly in the keel well/cavity. There is no evidence of hull damage that can be seen. The best guess suggests the leak is someplace in the keel well/cavity which we currently can't inspect on the trailer with any degree of success. If anybody out there has experienced this, or has any thoughts, it will be greatly appreciated. P.S. It has to be a slow leak because it could have taken up to 6 months to accumulate the water based on our last haul out and inspection.
