1985 to 88 27' Catalina
9
- - Charleston, SC
I am going to look at 3 27" Catalinas next week. Can anyone give me any advise about what problems I need to look for on these models? I have seen a thread on keel bolts leaks. Are these boats prone to leakage in any specific areas?
David H
Wow, there are so many answers to this question.
Best advice find the boat you want, with the equipment you want and then have it surveyed. Basic… Lights, rigging, obvious damage. Coast guard required equipment. MANUALS for any P.O. installed items Check bulkheads for water damage/rot from chainplates Mast compression post/base of mast on deck. Keel bolts Tight? All threads? Repaired with lags? Voids on deck…hollow sound Engine condition I'm sure others will chime in with much more. Good Luck
John/Illinois
Your Prefs & Sailing Home
Large variety of boats available. Big decisions are: standard or tall rig, outboard or diesel, wheel or rudder. Beyond that, buy the newest, most sound, best equiped you can afford. The 87/88 with an M18 diesel, wheel steering, tall rig will comand the highest cost and provide the greatest re-sale.
Jun 13, 2004
46
NULL NULL Treasure Island, Florida
27 catalina
Don't want to hijack your thread but I am also looking at a particular catalina 27 tall rig '85 for west central florida, has 14hp diesel universal. Anyone have info. on hull blisters for this vintage, I've heard it's a problem. I don't know that hull number of this particular boat but it's an '85 thanks.
jack
Doug
Doug, I have an 86 Catalina,27 loaded with extras in really clean shape. It's docked just a few miles from you in St Pete. Email sailorjack@verizon.net if interested. Jack
Tim Haibach
Catalina 27
I have a 1985 C27 in great shape with 14hp inboard diesel and wheel steering. I have had no blister problems although I have read some of the hulls of this vintage did experience problems but only a small percentage. Of course, after 22yrs, several things wear out from the original boat. But when you compare replacing some worn items with a new C270, you can have just as much fun at only a small % of the cost of a new boat. Boats from the 70's had mild steel KEEL BOLTS which might look rusted and wasted away. I'm fairly confident they took care of this problem by the mid 80's. My bolts are fine and I have no leaks from them. Other issues were mentioned like VOIDS in the deck from the resin not being able to seal the laminates completely. I didn't find any during my survey. Verify your SPREADER SOCKETS are stainless and not aluminum. Older aluminmum ones were prone to cracks at the weld and there have been a few boats that lost a rig due to this. Of course, periodic inspections should be a routine part of your maintenance schedule. CHAINPLATES should be checked for leaks. Have surveyor test with moisture meter. My upper shrouds (middle ones) showed elevated moisture around the base. I plan to rebed all my shroud bases this fall. Late 80's models have corrected many of the problems associated with earlier boats. If the major items check out fine: hull, rigging, and engine, then the rest can be negotiated and repaired/replaced over time. I agree, choose the best equipped boat you can afford. If the boat looks like the PO didn't care, then he/she probably didn't care about maintenance either.
