Hi there...this is my first post here.
I just aquired a 22' 1984 Hunter, fixed keel. This is my first mono hull. I currently and previsously have had a number of crafts, power (6), paddle (2), a sail board and a catamaran.
This model seems like it will be a great boat.
My 9 y.o. son and I went to do our initial visit yesterday.
Uhh-Ohh...she sunk in the stand with rain water. The rear cockpit was holding about 10" of water...below there was about another 6" of water above the floor level...all of the storage compartments were holding a good amount od water and so far as I could tell up under the cockpit was looking full too.
Both sails were on the boat. We raised them and they appear fine and the stiching seemed to be in good shape.
So far there only seem to be a few issues at hand that I need to get under control..
Rain water entering the boat..
Bilge pump
New Battery and charger and solar maintainer.
A lot of TLC clean up and a wet sand / compound / waxing of the hull and top sides.
A lot of lubing
New haylards and vang sheets.
replacing a top rotten lam section of the tiller arm.
One of the bigger items I'll have to contend with will be replacing the bulkheads between the forward berth and the main galley/salon area. These babies were ROTTEN...I probably could have pushed my finger through them.
MY BIG QUESTION...from a construction stand point...can these be starboard and still provide structural stabilty for the stay anchor plates ?
The floor boards were shot as well but these in starboard will not be a problem.
Another Q...this may sound really dumb...how taboo would it be if I installed a main / seasonal drain plug through the hull ?
Thanks for reading and any tips or suggestions or refernces you may have.
Bilge pump
A lot of lubing
