Jack Romoho
Noticed a leak coming from the starboard window frame. I siliconed the window frame.This did not solve the problem. Checked all surrounding areas with a hose and found the leak is from the traveler block.How can I remove the traveler block so I can reseal, to stop the leak??Is the block backing plate permanently fiberglassed to the superstructure?
