I recently bent my mast at the point where the two pieces join. I drove under a low power line. I managed to bend back the piece that inserts into the second piece but there are subtle areas that evidently have bulged and the insert does not go in all the way. If I can manage to gently hammer the insert piece to go in, do I need to be concerned about the stability? I should mention there is a very small hair line crack in the piece that inserts into the other longer piece.
Do I need to try to fix this or look for another mast? Are these available?
