1982, 37 cutter
Mar 5, 2012
152
Hunter 37-cutter Saint Augustine
Hello friends ,
I was wondering about what was the original prop size that came from the factory on my 37 cutter. as I have a max prop on it now that came with the boat when I got it.I have played with the pitch and it will max out at 3000 rpm but never see hull speed past 6.5 knots. I cruse at 2500 about 4.5 knots. oh yea its a 16 inch prop with what I believe is a 14 pitch. any help would be appriciated thanks all,
C&C Frigate 36 St. Margarets Bay, Nova Scotia
I believe that my 2-blade prop is original. It is a 16 X 15 RH. I have the 3QM30 engine. I usually see about 7 knots at 2500 RPM. (Less when the bottom is dirty or the waves are big.)
Mar 5, 2012
152
Hi Jim,
what is the maximum rpm that you can get ??? mine is 3000 no more
I never go past 2500. According to the manual, the 3QM30 is rated at 30 HP@2600 RPM (continuous) or 33 HP@2800 (one hour).
