If my memory from 30 years ago is still correct, the pivot bolt was located under the floor boards beneath table in the main cabin in between the ballast weights. The retracting cable on my Hunter 22 center board ( NOTE: it is not a swing keel) broke and I had to drop the center board to replace the line. It helps to have a travel lift or boat hoist available to do this.
