1981 h33 mast tuning
11
Hunter 33 Jacksonville
we have had her for 20 years and never adjusted the stays. Now there is a lot of sag on the leeward stays as well as some "dance" of the mast on the mast step when going downwind. Rig still has no meathooks or wear showing. Does anyone have the owners manual with the instructions for tuning the mast stays?
cheers
butch
Tim Dalton
tuning
I still have my manual and there is no description of how to tune the rig. Nonetheless, it is not difficult. Take out the cotter pins on the turnbuckles, grab the screw pin on the shroud with a pair of vise grips and use a screwdriver to turn the turnbuckle. The trick is that you need to tighten the shrouds on both sides to take up the slack in a balanced way--alternate P & S, I begin with the outer too. There are gauges that you can use to measure tension or you can do it by feel and trial and error.
If you have never touched your shrouds that probably means that they are original? If so they are way past their expected lifespan (some people say 10 years is the serviceable lifespan for shrouds). I replaced mine (1981 H33) about 6 years ago after noticing hairline cracks in the screw pins. If a shroud loosened up suddenly, I would be concerned about its integrity.
Nov 6, 2006
10,206
Mast Stuff
There is some great stuff on this site .. Here are a couple of useful things that were posted.. I apologize that I don’t know who posted them these will help.
http://www.ayesail.net/sailing/Hunter/Hunter23_45/index.html
Nov 6, 2006
10,206
The other file is too big to load.. If you'll send me a private message, I can shoot the file to you directly, Butch.
Jun 15, 2009
11
Re: tuning
She is the yard have holes from Faye fixed and complete paint job. New standing rigging is next on the list for sure..Thanks//butch
Jan 14, 2009
12
2 33 Port of Newcastle
I have a 1982 H33. Used a Loos gauge and set the tension at about 30. Everything seems snug (but not too snug) and no looseness on the leeward side. Seems to have picked up a bit of speed too.
Dave
