77 Hunter
Eric, I bought a Hunter 27 last May with all sails , loran ( outdated,I know ) VHF ,CB,all cusions ,Persevers, 15 hp mariner (water had gotten into the Diesel ) etc.etc,.for $1500.00. I have had the motor rebuilt and now have the boat here at home ,I had a number of blisters which I have reparied and painted the bottom with Durtec ,a two part sanding primer,before the anti-foul goes on next spring. I am replacing the grab rails as well as restoring the rest of the boat. I am covering the few stress cracks again with Durtec before repainting the decks,I have also removed all thru-hulls( except the main one)and re-glassed the openings.Bottom line, it is a good solid hull and great design,and I do enjoy working on her. Hope this helps ,if I can help you with info,just ask. Carter S/V IRISH FOX
