Recently picked up a neglected 1977 Hunter 27 with shoal draft keel. The boat has been on the hard for the last 3 years, so there is lots to do! The rudder has lots of play in it so looks like all the bushings need replacing. I also notice a slight tweak to port of the rudder itself, Not sure if the shaft is bent, or just because the bushings are worn so bad.. Can't find any info anywhere on what was used for the bearings/bushings. Any help would be appreciated. Thanks, Al
