1975 Catalina 22 Jib Winch
Mike
I sail a Catalina 22 and in heavier winds the winches make a grinding noise, and I would like to grease them up to prevent this from happening. I am not sure how to take the barrell off to do this. Any ideas on the best way to lube these winches up? Thanks..... Mike
Joe
this should get you started...
...go to the following link for a brief explanation. The most important points are: don't put winch grease on the pawls, and don't let bearings fall overboard. (Place small cardboard box with a winch-sized hole in the bottom over the winch to act as a parts tray).
Tony
Another good article
Here's another article that may be helpful....
Bayard Gross
Are these ARCO winches?
You may have ARCO number 6 winches, but maybe not. My C-22 built in 1981 came with ARCO Number 6 winches; however, I think your boat might have a different manufacturer. If they are ARCO winches, there is a clip washer around the top of the winch that is removed with a small blade or screwdriver. This will allow you to raise the drum up and off to get at the interior. However, as noted in the previous articles, things can easily fall overboard, including the clip washer. Hence you should only do this on a very calm day, or better yet on land. Loosing parts from old winches may necessitate replacement of the winch as these parts may not be available. Personally, I dumped my winches and use cheek blocks instead, as I have a furling 135. This is not an original idea, as I read about an individual that did this to his C-22 in Main Brace. However, this individual raced his C-22, and sought, as myself, a speedier way to reset the jib sheets after tacking. As I do nearly 99% of my sailing by myself, this is an important consideration for me. I also installed inboard tracks that do seem to give better pointing ability. I use spectra core jib sheets so that I do not have to deal with tightening the sheets only to get the stretch out of them.
