C
Chip
I have a problem and need some advice. My forward starboard shroud has broken loose a little below decks. It is not completely free but there is motion and I can see that one screw is missing in the fitting on the deck which holds the mounting bracket to the deck. The shroud itself seems to be very loose when compared to all the other shrouds and stays.It appears that there are a couple of metal plates with three bolts which are holding the shroud in place below decks. The metal plates and bolts extend down through the deck and into the cabin closet across from the head and aft of the v-birth. It looks like the wood has disintegrated in the vicinity of the metal plates allowing the plates to give way. I think I can fix this problem by replacing the metal plates with larger metal plates which would sandwich the remaining good wood of the bulkhead between the v-berth and the closet and provide a firm base for the shroud but I would like opinions on the viability of this option.It also looked like there may have been a water problem in that vicinity at some point so I suspect that the mounting screw came out and allowed water to enter that area and over time caused the wood to deteriorate. Is this making sense?Is it safe to release one shroud (forward starboard) at the base near the deck topside in-port if all the others shrouds and stays are firmly mounted? I think I am going to need to do that in order to make the repair in that way.Is there a different/better way to address a problem like this?Thanks again!Chip
