I am a new owner of an old boat and I need to replace the original
equipment that has been removed. The Hunter 18.5 mast I do not
believe has a mast hound for the forestay. I assume its a "T" ball swage
fitting originally?
I also have a wierd external fiddle block mounted to the upper
exit hole for the jib halyard. I assume this to be a thru-deck block type of
hardware originally?
if you find a moment to take a photo of this area of the mast it would
sure help out a fellow sailor. or better a hunter production elevation drawing with legend. I would greatly appriciate any help you might offer.
Thanks,
Andy
fitting originally?
Thanks,
Andy
