170 -Trailering with outboard engine
feejer
Sep 17, 2005
57
- - S.E., PA
The 170 will most likely be the boat I buy. I'm thinking about the Honda 2hp 4 stroke. My question is, can you trailer the boat with the engine on the bracket? Or must you remove the engine and store it when your trailering.
May 22, 2004
55
Hunter 170 Brewerton
Always Off
I always remove the engine. Mostly cause don't know how much jarring the bracket mounts can take. Better safe than sorry! Joe
- - Owensboro, KY
Leave it off
I agree with Joe, the bracket mounting is not strong enough to take the jarring. I fashioned a motor bracket with treated lumber that I attached under the trailer winch. Now I don't have to mess with putting the engine in the car. Drove to FL and back, worked great!
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
I take mine off
I do like Edwin. I fabbed a bracket to hang the motor on the trailer. Jerry
Aug 31, 2004
84
Oday 322 St Clair Shores
motor bracket
Edwin and Jerry - great idea! Jerry, thanks for the photo, I am going to try that when I get a motor next year. I can't quite see from the photo how you attach the 2x4 to the mast brace. Can you reveal your secret?
K
Kris
take it off
We have a Honda 2hp, 4stroke on our 170. We never travel with it on. Plus it is very expensive, if you leave it on, for someone to easily take on your boat/trailer. Lock it somehow if you are doing the bracket thing. They are hot to take.
JerryA
Bolted to the winch
David, I mounted it using the two bolts that hold the winch. It's actually more than a 2x4. It's a piece of 1.5x3 galvanized "U" channel with a short piece of 2x4 inserted into it to give the motor clamp something to hang on to. The "U" channel bolts to the winch bolts. Works pretty well and is heavy enough to support my Honda next year. Jerry
