150% Genoa: Tracks Required?
K
Kevin
I am considering add a 150% genoa to my sail inventory. Are tracks need for the fairlead blocks for the genoa jib sheets? I have a 1985 shallow wing keeled boat.
Jerry
Yes, You need a Track
Kevin, You will need tracks and sliding blocks for a 150% Genoa. You can look in the archives. To get an idea of what a factory installation looks like, scroll to the bottom left of the main page of this site, click on THE BOATS, and again on "23." You will see the specifications for the H23 and pictures showing the track. Jerry
K
Kevin
Thanks Jerry
Jerry: Thanks for your recommendation to check the archives. I've being looking at the H23 picture on the home page all this time and just noticed the factory track installation! - Kevin
Apr 19, 1999
1,670
Pearson Wanderer Titusville, Florida
If you have a second sheave above the. . .
...forestay tang on the mast, run a third halyard and mount the two jib blocks that you removed on the rear quarters of the boat. Voila! You are now set up to fly a spinnaker. The spinnaker sheets run aft to the old jib blocks and then forward to the main winches. Have fun! Peter H23 "Raven"
K
Kevin Keen
Thanks Peter...
with your response, I can now set all the hardware for all necessary running rigging for my H23. - Kevin.
Sep 25, 1999
601
Hunter 23.5 Indian Lake
site pics track
I have tried many times since reading this to see the track on the h23 in the jpic in the boat section , I guess I am blind, I do not see the track, , what am I missing ? thanks Mike
Joel
Shadow Track
Every time that I've looked at the picture, the only thing that I could see is the shadow of the jib sheet running fromthe block back towards the winch. If you look quick, it appears top be a track but I believe it is really just a shadow.
Joel
Not crazy, Mike...
Just too long away from the water. It hasn't been a bad winter for us out here near Boston but I sure can't wait to get the boats back in again. My only "boating" experience the last few weeks has been knocking the snow off the top of the tarp. I did climb up into the boat once but spent the whole time "in irons" although the boat was up on the trailer too. That might have had something to do with the way it was tacking that day. -joel
