If you can't find it by googling it or calling the factory and you have a masthead halyard just measure the halyard from the deck to where it exits the mast. Use the halyard to hoist a spare line. Mark the line at the deck then measure between the marks once you pull it back down. Then measure the height between the waterline and mast step on deck. Estimate the mast height above the masthead halyard sheave and add them all together and you should have a fairly accurate height.
