12v wire run
Dick
I want to run 12v from battery forward to area in bow where previous owner put a 20g water tank. I want to put a demand pump up there to provide presurized water to the two sinks. What is the best route? I would, also, like to find a way to put one of those retractable showers in the cockpit. I'd use it for both a shower and a cockpit washdown. Any suggestions? I'm sure I could T into one of the sink supply lines. I'd guess that water sitting in the tank all week in the closed up boat would be pretty warm.
C
Crazy Dave Condon
12 volt
The wiring should come down from teh panel hopefully behind and down underneath the galley and then run forward. Suggest either # 16 or 14 wire. You may want to cover the wire with a tube(I use a corrogated black pipe that is cut in the center)for protection. Secure the wire down. If you are going to put in a transom shower, then t off the line to the sink in the head. Crazy Dave Condon
Dick
Shower
Any specific location for shower/washdown? Type or brand? Cost?
