12V switch panel
Apr 24, 2011
32
Hunter 41DS Riviere Sens, Guadeloupe
None of the switch indicating the lights on the DC side of the switch panels do not work. When I switch on "panel lights" the AC side works but not the DC. I don't mean the light on the actual switch, but the title lights with the names of the switch.
Any ideas.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
So your dc switches work but just the little light the shows the switch name doesn't? If all are not working, it's most likely a wire is off or corroded on the bus that powers the lights. Can you get behind it and see?
May 24, 2004
7,202
CC 30 South Florida
Its, either a bulb or fouled wiring connection. Get to the back of the panel but first disconnect (not just shut off) the shorepower cable.
Apr 24, 2011
32
Yes, that was what I assumed but it appears the DC side and the AC side are connected by the same wire. I had a look last night and all the connections look sound. Will have another go today.
May 24, 2004
7,202
CC 30 South Florida
It is likely that the panel lights on both the ac and dc sides are 12V powered as you would likely need them when underway or at anchor. It makes sense to have the light bulbs connected to the same circuit and since one side is working it points to a faulty bulb in the other side.
Apr 24, 2011
32
So one bulb for all the switches or are they in series like Christmas tree lights and I have to check them all until I find the faulty one?
kito
Sep 13, 2012
2,011
That's what I was thinking. It's not just one bulb but each switch has it's own LED or bulb correct? Sounds like a bad connection common to all the bulbs to me.
Apr 24, 2011
32
OK,thanks I'll take the cover off again and look at each panel beside each switch.
Thanks again
May 24, 2004
7,202
CC 30 South Florida
I believe you are talking about backlit illumination lights for the panel titles. Don't know what year your panel is but newer panels are backlighted by a series of LED bulbs embedded in a printed circuit board which is replaced as a single unit. In the past different configurations of incandescent or LED bulbs were used. No sense in continuing to speculate what may or may not be until you get to the backside of the panel.
Apr 24, 2011
32
Removed panel and amongst the spaghetti behind discovered the lights are on a printed circuit board and it looks a real problem to remove. My electrician having looked at the problem suggested a torch given the cost of removal and replacement plus the probability of messing up other connections, wasn't worth it. So that's what I am going to do.
