I'm refitting my '83 h25 and ahve a general question about the electrical wiring as I'm re-wiring all of the lights, instruments, etc. I know that in simple DC setups negative is ground. I assumed that the negative side of things should be attached to the bonding system. In my setup the negative bus bar and negative battery terminal are both routed to the keelbolts (the bonding system?). In "upgrading the Cruising Sailboat" Daniel Spurr says that the bonding strip should never be used as ground.
Can anyone shed any light on this?
Thanks in advance.
Dave Bryant, s/v Jolly Good
Lake Lanier, GA
Thanks in advance.
Lake Lanier, GA
