F
fred miller
I'm adding a new wind instrument to my complement of a depth and a speed ST 50s. It will be mounted right along side of the others.[there is an existing hole where the old wind instrument was]. I know about running the cabling to the mast head for the wind direction and speed indicator, but can I tap into the 12 volt feed that powers one or the other of two existing instruments to save the chore of having to run new wiring all the way back to the 12volt panel?It really does not matter to me if the new and the old instruments fire up simultaneously [I don't need separate switches]. Is this advisable? Do I run the 12volt feed from either one of the two existing instruments to a terminal strip and then branch off to the new instrument or tap directly into the terminals on either of the existing instruments? Should I fuse the + side of the new feed? What guage wire? Any other ideas?Someone mentioned wiring in parallel vs series, what does that do for me and what does it mean?Help is always welcome . .Fred MillerS/V M-Squared
