How does one operate the 110vac refrigerator while cruising and no shore power available? Do you run the generator constantly?
You may be looking at the idea you could buy several 110 V fridges for the price of one 12 V fridge.Given that the reefer is one of the biggest power users on your boat it makes sense to make its power supply as efficient as possible and use 12 volts directly.
I have always wondered why 12v fridges for boats/RV's are so so much more expensive than say a similar sized 110-120v dorm sized model like people buy for keeping the garage beer cold. Plenty of those available from $100 - $200.You may be looking at the idea that you could buy several 110 V fridges for the price of one 12 V fridge....
It is economy in numbers. There are tens of thousands of 110 volt fridges produced for each 12 volt marine fridge made. The same would be true of a dual motor fridge.I have always wondered why 12v fridges for boats/RV's are so so much more expensive than say a similar sized 110-120v dorm sized model like people buy for keeping the garage beer cold. Plenty of those available from $100 - $200.
Couldn't a manufacturer just replace the 110v compressor motor for with 12V motor instead? The manufacturer could even put in two motors one AC and one DC for the owner to switch around depending on whether at a 110AC berth or out on water with only 12V.
And still would be a lot cheaper than every marine dual sourced 12v or 110v.
But also I guess boaters can't risk an inferior model going bad while on a trans-oceanic crossing.
